RE: perry pump for OS 120 AX - does it help
I'm running a Perry pump on my 120 AX and it works fine.
If your using a pitt's muffler you will eventually need to put one on due to the lack of pressure from the pitt's causing a leaning condition half way thru the tank. Or if you have the tank mounted on the CG and your fuel lines are long.
