RCU Forums - View Single Post - Another Tipo Question
Old 11-20-2008 | 01:52 PM
NM2K
My Feedback: (14)
Default RE: Another Tipo Question
ORIGINAL: doxilia
MJ,
I'd have to agree with Roary. You can use standard size servos without them costing too much. In fact, there are some great coreless analog servos (Futaba and Hitec). Mini is also a PITA to install in a foam wing. Why not just make things easier for yourself?
Keep in mind that although it is for fun, it still is a fast 60 sized pattern ship. Nothing worse than saving $10 on a servo just to see your aileron or, worse, elevator flutter and then rip off!
David.
The Hitec HS-225 servos are still fairly robust, when compared to micro and other mini servos. They should have plenty of strength, speed and mass to handle one aileron of a Tipo. I wouldn't want to go much larger than that in load with a 10cc engine, though.
Remember when we used torque rods and one 28 inch/oz. Kraft servo for moving two ailerons in a contest model? Wasn't all that long ago - or so it seems if you are an OF. <G>
Ed Cregger
