Sheeting
This will be my first attempt at sheeting a wing, a foam core one. What do you all recommend i glue the 4"x48" sheeting together with i've read that CA is fine some say Titebond wood glue is better So far the plan is to save weight so the sheeted wings will be covered in Ultracote instead of fiberglass
after im done making the wing skins i plan on using gorilla glue to glue them to the foam cores
