RCU Forums - View Single Post - Reynolds number question.
Old 03-19-2002 | 05:16 PM
ChuckN
Default Reynolds number question.
Reynolds numbers are unitless values given to flow situations so that one can compare apples to apples. It's sort of like a representation of the number molecules flowing over a surface over a given period of time, but not exactly. You are right that a full scale wing section will behave differently than a scale model wing section of the same airplane. For small wings the air seems more "syrupy", if that makes any sense. Laminar flow is preserved over a much larger percentage of the wing than at larger reynolds numbers, which correlates to larger wings and/or higher airflow speeds. Insects take full advantage of this.
If I'm not mistaken I believe Mr. Reynolds was actually in charge of the sewer system in England over a hundred years ago and developed a system for calculating fluid flow through the pipes under London.
