RE: Internal differences between .60FSR and .61FSR?
Bryan,
The distance between the crankshaft center-line is comprised from half the stroke + con-rod on-center length + piston's compression height (from wrist-pin center).
It should work, but pre-fitting is imperative, to make sure nothing runs into anything else...
