RCU Forums - View Single Post - charging lipos
Old 11-21-2008 | 09:05 AM
CGRetired's Avatar
CGRetired
Default RE: charging lipos
I have both the Triton and the ICE. I mostly use the ICE, it is easier to program, and does the LiPo's as well as NiCd and NiMH packs.
CGr.
Edit: I forgot.. .1C or lower for normal safe re-charge. ( .1C is = to 1/10th of the total battery capacity, which is conservative, but is probably the safest charge rate). For instance.. 2100 mah is 2.1Amps or 2100 miliamps. Charge it at 210 miliamps will take 10 hours.)
You can fast charge it at 1C (field charge) or, in the above case is 2.1 Amps or 2100 miliamps, and that's just fine. If you have the time (overnight for instance), then the .1C is the better way to go. But 1C will work.
Always ALWAYS charge LiPo packs outside and use a LiPo sack or some sort of fire protective enclosure. Do NOT charge in your home or car.
CGr.
