ORIGINAL: jaka
I do not recommend Dave Brown Southern Sorgum contact glue or any aliphatic or white glue as these glues cannot be used in the above manner!
When using those you just let them dry before you roll em onto the foam wing...which is not a good method to use if you want a straight wing! Even if it could be done...
Well I have to disagree some with you about a straight wing. Once the Sorgum is applied to both surfaces and allowed to dry, you use a sheet of paper and lay between the foam and the skin. Once you have everything lined up the way you want it, then start removing the paper and laying the skin on the foam. It is normally a rolling action. Never had a wing that was warped as a result of this process. If you are just trying to slap the skin on, Lords know what might happen. It is like the food ad "try it, you'll like it"
