RCU Forums - View Single Post - Dr. Jekyll Pattern plane ??'s
Old 06-19-2003 | 11:19 AM
AeroJote_RRF
Default Dr. Jekyll Pattern plane ??'s
Hi Adil:
Finally, I took the measurements (all in millimeters):
Ailerons High Rate: 15 mm. Up and 10 mm. Down.
Ailerons Low Rate: 15 mm. Up and 10 mm. Down.
Elevator High Rate: 20 mm. Up and 23 mm. Down.
Elevator Low Rate: 13 mm. Up and 15 mm. Down.
I forgot Channel four ...
I use High Rate only for Snaps and to enter in Spin.
Regards,
