ORIGINAL: AncientCityFlyer
Mobyal, I see that you've ordered a Sparrowhawk. I've been seriously thinking of get one too. I went on-line to Atlanta Hobby and downloaded the pdf manual. The manual is very typical of the China/ Vietnam model companies. Mostly pictures and little good info. On the first page of the manual it says for engine size...1.60 2-stroke and 1.80 to 2.00 4 stroke???? Yikes, that even bigger than whats been advertised. Seems WAY too much power for that size airplane? Plus in the advertisements it mentions a 20-26 cc gasser but not in the manual. Looking at the manual it shows an O.S. 4 stroke inverted, using a strange looking muffler, and really carving up the cowl. I'm not to thrilled about doing that. I'm also wondering if a small gasser would even fit inside the cowling? The rest of the plane looks good. The model uses a pull-pull cable system for the rudder and dual elevator servo's which is good. The landing gear looks interesting also. Looks like a bit of a shock absorbing bend in the trailing link gear wire. All-in-all, it still looks pretty good. I'll be watching for your posts as you start to build. Mike (ACF)
The funky looking muffler would be the NEW OS four stroke muffler on an older OS 1.20. They are butt ugly to me.
