RCU Forums - View Single Post - 12x programming question
Old 11-21-2008 | 09:51 PM
CraigG's Avatar
CraigG
My Feedback: (40)
Default RE: 12x programming question
ORIGINAL: CraigG
Keith,
I ran into the same thing. Apparently the 12X only lets you use the sliders on certain aux channels. Why? I have no idea but it sure would be nice it you could use them on all the aux channels. I had to rearrange my channel assignments mid-programing when I discovered this limitation.
Craig
OK, new information has come to light and it looks like I was not entirely correct with my response above. When you use the DeviseSEL function on the start-up menu you only get limited switch selections on some channels as Keith has indicated. However, if you wish to assign a channel to a switch not indicated in the DeviseSel graphic you can still accomplish the same thing with an unused P-mix function (51-58). Select the P-mix, then select the switch you want to use and assign it as the master ("Mast") and mix it to the channel you want to use.
In Keith's example, the left slider ("LLVR") or right slider ("RLVR") can be mixed to any Aux channel. Set the Pos values and you are done.
Still not sure why they don't just include all the switch positions in the DeviseSEL menu for all channels but at least there's another method to do it.
Hope this makes sense.
Craig
