RE: Lets talk about timing...
From a retarded setting, increase timimg little by little, until you find best rpm. that is the setting you will want to run.
If you advance further, rpm will remain the same, but the engine will start to run rough, and plug tuning (judging) will become confusing. There will appear a burnt ring at the end of the central electrode. Retard ignition again until this ring disappears.
