RE: Top Flite AT6 ARF
The gear wire is 5mm, and soft as cheese, no spring at all. I'm wondering if anyone other than me has tried to remove the gear wire from the retracts after the set screws have been torqued down?? It's nearly impossible because the wire is so soft it gets distorted.
Flys great though, just make soft landings.
Ethan
PS. I remove the set screws before trying to remove the wire struts.
