RCU Forums - View Single Post - 257" B-36D Build
Old 11-23-2008 | 09:19 AM
  #52
FliteMetal's Avatar
FliteMetal
Default RE: 257" B-36D Build
If you skin with G-10 along the constant diameter section you would achieve surface hardness with tension and compression at the same time. The Monogram 36 provides a more than adquate size perspective I assume you are going to use C/F truck and strut components.
