ORIGINAL: FliteMetal
If you skin with G-10 along the constant diameter section you would achieve surface hardness with tension and compression at the same time. The Monogram 36 provides a more than adquate size perspective
I assume you are going to use C/F truck and strut components.
Where can I get G-10 in 4X8 sheets, what does it cost?
Thanks, DAG
