RE: U-Can-Do 3d 46?
Dylan
This plane does not need dual elevator servos. It is just extra weight and cost. I have a Flip that I joined the elevator halves with a small piece of plywood attached across the underside of both. A piece of carbon fiber plate would be perfect.
To do this simply place the joining plate on the top or bottom of the elevator . Then mark the radius of the joiner plate on the fuselage and cut it out. It will be more or less a 1/4 circle. Then simply glue the elevators together
