RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 07-20-2003 | 07:58 PM
  #263
Dylwad
Default RE: U-Can-Do 3d 46?
i havent taken any detail shots yet, i will take one of the damaged rib that i found lurking under the covering.....also there is a plywood plate glued on the bottom aft fuselage, looks like a tailwheel bracket mount, one of the things i was going to do. all in all though the construction looks real nice, however i am going to be going around it with thin CA on a few spots. which detail shots would you like to see?
Dylan
