RCU Forums - View Single Post - Lets talk about timing...
Old 11-23-2008 | 02:05 PM
nitro joe
Default RE: Lets talk about timing...
Quote:
“A person with a magnetic timing light, the type that closes around the spark plug wire, MAY>>MAY get enough signal through the shielding to see the firing time.”
If the shielding wont let you pick up a signal, you might try clipping the whole plug wire with the plug connector off an old mag coil.
Then strip back a couple/three inches of insulation,fold that wire enough times on itself to fit the center post connector in the cap completely,and tightly.Secure with a wire tie.
Run a temporary ground wire from the lead shielding to the engine. Pop this “test jumper” on the spark plug.
You will now be able to pick up your signal. For testing purposes,on the ground only,of course.
Edit to add pics.
ID:	1077427   Click image for larger version
