RCU Forums - View Single Post - Cap 232 a good beginner low wing?
Old 11-23-2008 | 08:40 PM
Steve Steinbring
Default RE: Cap 232 a good beginner low wing?
Pangi,
Its not a Goldberg but a Tower Hobbies ARF.
I too am an instructor and have different thoughts about second airplanes than Gray Beard. IMO it would be better to get a little wider range of flying experience before taking on a warbird or scale acro ship. You can push the Kaos 40 around quite a bit it does pretty good acro for what it is. My airplane is a little weak on doing knife edges and stall turns(could be the pilot[&o]). Believe me theres a lot to be learned from a older stable pattern design airplane. The Kaos 40 from Tower is just $119.00 before any discounts to its an affordable second step trainer. I have a OS.46 AX as the power plant giving the bird all kinds of performance and almost unlimited vertical.
Good luck on your quest.
Steve
