RCU Forums - View Single Post - Baffles - Will this work?
Old 11-23-2008 | 10:54 PM
RTK's Avatar
RTK
Default RE: Baffles - Will this work?
That will be perfect. The idea is not to force air in, but pull it thru and out. Put a low pressure lip at the exit and you will be fine. All the air will have to pass thru the fins and will be pulled out the bottom
