RCU Forums - View Single Post - DX6i SETUP FOR RAPTOR G2
Old 11-24-2008 | 03:29 AM
yadac123
Default RE: DX6i SETUP FOR RAPTOR G2
did you set the swash type to 1 servo? under the swash menu did you set the range for the pitch?
if your alieron servo and elevator servo is good try plugging them to the aux 1 and see if you still get the +2. If yes, then it's not a servo problem.
Andy
ORIGINAL: cjennjr
Andy - I just purchased the Spektrum DX6i for my Raptor G2. Everything is set with the exception of the pitch servo - it doesn't want to move!!! I have it hooked up in the AUX slot on my AR6100, and I have max settings for movement, yet it only moves approx. +2 degrees max. What do you think is wrong? Gyro is good, aileron and elevator is good; and yes, the servo works. Thanks in advance!
