RCU Forums - View Single Post - Carb Stuck Shut...
Old 11-24-2008 | 11:47 AM
crossman
Default RE: Carb Stuck Shut...
I had the same issue with an OS 40 FP a couple of years age. Take the carb off, remove the plastic lever and the rubber O-ring on the bottom. Then put in some denatured alcohol overnight. If that doesn't free it up, you can try disc brake cleaner. Same thing, just let it soak for a few hours. Mine works like new now.
Chuck
