RCU Forums - View Single Post - perry pump for OS 120 AX - does it help
Old 11-24-2008 | 04:32 PM
McChiken's Avatar
McChiken
Default RE: perry pump for OS 120 AX - does it help
Yeh , the .75 has a raised area in the center big enough to drill and tap . My .46 does to but it is not big enough to drill and tap . I think it is part of the design on the casing to add strength .
I will be padding all sides of my tank now . The original design of the plane had the tank fitting through a plywood structure in the fuselage with no room for foam except in front of the tank and behind it . Since im rebuilding the whole bottom front end of the plane I will be able to make room for foam .
The pic with the big round nob in the center is the .75 the other is the .46 . I also made about 8 sets of these motor mounts outa T6061 aluminum and am going to try and implement some rubber in them like those ISO mounts you have .
ID:	1078308   Click image for larger version
ID:	1078309   Click image for larger version
