RCU Forums - View Single Post - senior telemaster build
Old 11-24-2008 | 08:11 PM
senrak
Default RE: senior telemaster build
Bolt on wings are easy on the Telemaster. Go about it as you would any other high wing. Add a piece of plywood in the front of the fuselage to hold a couple of 1/4" dowels placed into the leading edge. Add drilled and taped blocks to the fuselage sides and re-enforse the trailing edge where the nylon bolts will go through. Simple and effective.
Oh, and dihyderal, it doesn't need any. Flys just fine.
