RE: one way valve
why would you need a "check valve" on the muffler's pressure line? you would have to disconnect the check valve to refuel as the check valve would not allow you to vent the air out of the tank.....the only place I know of a check valve is on a gasser's vent line to keep dirt and crude from entering the tank through the vent..which is on the bottom of the aircraft.....
Good flyin to ya
