RCU Forums - View Single Post - Engine Mount ...Tap?
Old 11-25-2008 | 04:43 PM
bruce88123
Default RE: Engine Mount ...Tap?
First I hope you meant a 6-32 x 3/4 screw. #6 is the size, 32 is the thread pitch and 3/4 is the length. Using a nut on the back depends a little on the shape of the mounting beam, best to have a flat surface to bear against. Why thread lock if you have a lock nut?
