RE: Engine Mount ...Tap?
Ken is correct in that thread lock can attack many types of plastics making them either soft or brittle. JR has a warning out against using it on their servo output arm mounting screws. If a tapped hole is done carelessly and the threads are a loose/sloppy fit then you will also need a lock-washer under the screw/bolt head.
