RE: Extreme Bashing in canadian winters!
I've tried extreme winter bashing and it just doesn't work out. The plastic parts become brittle and break very easily. Regular winter bashing is fine though. Make sure your engine reaches proper temps, and prevent water from reaching your electronics. After each run, remove the water as quickly as possible as it will cause steel parts to rust.
