RE: Problem with Ignition System
I forgot to add...the sensor leads are sometimes quite fragile and can get physically damaged. I suspect that is what happened or th sensor went bad on its own, not your fault. the use of clear silicone rubber where the wire meets the probe can help. Capt,n
