I used something like this,only homemade
.You know,hammer and nail
!But how am i going to put the chain back together?Those little pins,are a bit bigger on the ends so that can hold the chain links.If you use a chain breaker you are going to shim down those bigger ends and you end up with a simple pin that slides in and out of the chain
