Roo with elevons only
Kangaroo does not have a tail and therefore cannot be flow with "Elevator". A delta wing platform uses Elevons which is a combination mix via the radio so the aileron works as elevator fuction as well. You dont need rudders on a roo, for that matter they are barely enough as supplied to be effective but the AMA requires rudders on all turbine powered aircraft, thus the reason we all have them.
Todd
