RE: YS engine disasembly?
I was able to get it apart today. Really wasnt to bad. I kindof learned as I went. Everything looked good exept for the bent crank. They dont like to hit the ground too well from 50 ft. It looked like more of a job then I thought. The only thing that had me thinking for awhile was getting the connecting rod off the crank until I figured you had to remove the wrist pin out the side of the cylinder. Is central hobbies probably the best place to get parts from?
Jeff
