RE: Wheels needed!!!
You really don't need them on a EDF plane. I could see if you were runing a turbine, But with a EDF just come in and use your elevator as a air brake. If that does not work you can put a o-ring on both side of the wheels and tighten them down a little tighter and that will make the wheel not roll as fast and it should slow down just fine. I hope you can use any of these things. Eric
