RCU Forums - View Single Post - What is a pull-pull system?
Old 11-27-2008 | 01:35 PM
DMcQuinn
My Feedback: (13)
Default RE: What is a pull-pull system?
Most often for the rudder and most often found on larger planes. You use two strings ( or Kevlar or steel cables) to connect each end of a double servo arm to similar horns on the rudder. Picture a parallogram. when the servo turns, the rudder turns. It is lighter than a push/pull rod that you typically see to control movable surfaces.
