RCU Forums - View Single Post - Super Tiger 45ABC Italy
Old 11-27-2008 | 02:33 PM
  #57
rainedave's Avatar
rainedave
Default RE: Super Tiger 45ABC Italy
OK, folks, we have the test data.
Temperature: 60° - clear, sunny and low humidity (for North Carolina)
Fuel: fresh Powermaster GMA 5% Nitro, 22% castor/synth blend
Glow Plug: brand new Fox Long (non idle bar)
All props are 11x6. With each prop I leaned the needle valve until RPM's dropped and then backed off a few clicks. So, these are peak numbers.
MA Black:
13,550
6.4 lbs. static thrust
1.15hp
66.9mph
MA 3 Series:
13,477
6.76 lbs. static thrust
1.24hp
66.5mph
Evolution (I chose a prop constant value of 1.15 which is lower than APC, but, higher than MA-S3):
13,146
6.62 lbs. static thrust
1.21hp
64.9mph
APC:
12,853
6.52 lbs. static thrust
1.18hp
63.5mph
Graupner:
12,406
6.91 lbs. static thrust
1.29hp
61.3mph
I'm waiting for comments...
David
ID:	1079932   Click image for larger version
ID:	1079933   Click image for larger version
ID:	1079934   Click image for larger version
ID:	1079935   Click image for larger version
ID:	1079936   Click image for larger version
