RE: ROBARTS ZIROLI 92" ARF ASSEMBLY
Miscellaneous
After being stuffed with turkey and the 'kids' left, I did a few things (besides loosening the belt buckle!).
pic 1:
I installed the contact switch for the landing lights.
The green wires were just connected between the main landing lights on/off switch to the lights.
The opposite side of the servo arm moves the contact switch to open the connection when the landing lights are up.
This contact switch is nice because you can use the center post and one outside post if you want the switch to turn the lights on or use the two outside posts to turn the lights off (which is what I needed).
The space to the right will be the location for the canopy air valve and servo.
pic 2:
All's working on the landing lights.
pic 3:
Also, screwed in the 50 cal guns and put the drop tanks on.
Having those drop tank pylons on is going to make wing bags a little 'difficult'.
pic 4-6:
I double checked the nav lights.
Turned the flash off to get the nav lights to show but any camera movement gives some blurry pictures.
