RCU Forums - View Single Post - I dont know?
Thread: I dont know?
Old 11-28-2008 | 06:59 AM
Witterings
Default RE: I dont know?
Won't make any difference if your Sim is 4 channel and your plane 3 that's exactly how I learnt, I also didn't know which sticks should move what and had them set up wrong for the 1st week and then had to learn a second time to get it right.
The E-Sky Simulator should be the FMS software, open it up and on the menu on the top click controls and then analogue control on the drop down box. In the interface menu highlight joystick interface and click on mapping / calibration.
In the menu that opens from top to bottom in the channel boxs the numbers should be 4 2 1 3 and then again for Heli's 4 2 1 3, in the next line down under Inv all of the boxes should be ticked and that should be set up properly for mode 2 which is probably the most common and what your J3 is.
When you then go to the plane the left stick up (away from you) should increase throttle.
The right stick pulling it back towards you the rear of the elevator should lift which will cause the plane to climb and the reverse if you push it down, if you move the stick to the left the rudder should deflect to the left and the plane will turn left and vica versa.
On the simulator you'll be turning with ailerons which will be in the same place as the rudder on your actual plane ie on the right stick, this is so you get used to turning with the same stick so it's not confusing when you go from 3 to 4 channel using ailerons to turn instead and is meant to be like that !!!
You'll find landing the Sim is harder than the real thing, make sure you've loads of space as you'll probably overshoot, on your first flight practice as though you're going to come in to land to help get the feel but increase the throttle and accelerate away again a coupe of times, make sure the planes got a straight line towards where you want to land bring it in and down slowly, decreasing the throttle will also help the plane loose height as it has less light!
If you don't understand any of that let me know and I can fill in the gaps.
