RCU Forums - View Single Post - Weird Saito 82a behavior.... 4-Stroke gurus, Help please.
Old 11-28-2008 | 11:33 PM
n19htmare
Default RE: Weird Saito 82a behavior.... 4-Stroke gurus, Help please.
ORIGINAL: alan0899
G'day Mate,
It needs more prop, a 13x7 is not enough load, it is a 4 stroke, & must be run like a 4 stroke, I would try 14X8 APC, & retune.
http://saito-engines.info/prop_sizes.html
I tried a 14x6 MA prop, same thing.
ORIGINAL: chashint
If you have not leaned the low speed needle you need to do that after you switch props and retune the high speed needle.
I leaned out the LSN almost 1 full turn..... Still plenty of smoke and doesn't bog down the engine when I go WOT.... so lean out the LSN more?
