RE: BH MODELS (CAP 232)
JYM,
Good name! I am also considering buying a BH Cap 232, as I have found one cheap. I am, however, trying to find out whether my Saito 270 twin will fit totally inside the cowl. I wonder if you would be able to take some measurements off your cowl for me please? The main dimensions that I am after are the width of the cowl "cheeks" at the front end and at the widest part, and the height of the cowl cheeks (too see if the rocker covers will fit inside). But there are some others that would be really helpful too. See sketch below for the dimensions I am after (dimensions numbered DIM1-DIM5, some are repeated on different views).
Thanks in advance,
James.
