RE: Boomerang Sprint Build Thread!
50 ounce tank fits perfect and gives between 5 & 6 minutes on the P60 depending on your throttle stick and still leaves a safety "overshoot & go around again" margin.
60" span, prototypes dry weights were from 10lb 2 ounces to 11lbs 8 ounces depending on the turbine used.
