ORIGINAL: warbird_1
well that sucks . I would think by now someone would have come up with a tiller arm setup for the newer nose gear so you wouldn't have to deal with stone age setups like pull pull cables . I have spring air gear in mine that uses an arm to steer with and I didn't even have to spend 600.00 to get it. makes you wonder where all the money goes. surly not in R&D.
Wow! I've used the SpringAir tiller arm and it constanlty broke. This was on a lighter weight jet at 10 pounds 15 ozs. I switched it to cable steering and have not looked back. "Stone age" cables that work or new fangled arms that break? MY choice is clear.
Dave
