RCU Forums - View Single Post - Best Way to Add Weight to the Front of Your Plane
Old 11-29-2008 | 09:52 PM
Stick 40
Default RE: Best Way to Add Weight to the Front of Your Plane
ORIGINAL: build light
While on the surface the heavy prop nuts and prop washers seem like a good idea and it does get the weight further forward than some methods, I just cannot help but think how this cannot be good for an engine running and flying at the same time.
The extra gyroscopic effect in flight (worsened if you use a larger prop, also a way to get extra weight out front) would be combined with the extra weight to shorten the life of the engine.
The extra battery pack idea is much more favorable but may not be enough. Any possibility of lighteninf the other end of the plane just a little? A little can go a long way. Often a third of an ounce lost in the rear can mean one ounce less to add up front.
Good luck, Robert
I would agree with this if I was flying a high rpm engine, that I was reving up and down a lot doing paterns . But a slow flying cub with a four cycle on it , I think the heavy prop nut can help with low and slow flying. It acts like a fly wheel and helps keep the motor running at low rpms.
I have put lead under the foam for the fuel tank, the very bottom of the plane. Its a safe place and as forward as you can with out mounting it on the fire wall. I don't like to mount it to the fire wall , I think it can help break the fire wall free from the fuse.
sticks
