RCU Forums - View Single Post - ROBARTS ZIROLI 92" ARF P-47 ASSEMBLY
Old 11-30-2008 | 09:24 AM
  #183
samparfitt
My Feedback: (43)
Default RE: ROBARTS ZIROLI 92" ARF ASSEMBLY
Inner cooling functioning doors.
pic 1/2:
Two control horns were screwed/epoxied to some balsa triangular block and then epoxied to the door supports.
Also, some 1/16" thick ply was cut and epoxied to the door to keep the door from flexing.
pic 3:
The tray was cut for the servo and some balsa blocks were epoxied to each end for the servo screws.
I used balsa for the servo blocks to save weight since this is behind the CG and moving doors is not a critical failure should they come loose. I'll CA the holes in the balsa to give them some extra strength.
ID:	1081331   Click image for larger version
ID:	1081332   Click image for larger version
