might work for you
From one of the many "uses for cola" sites...
Don't know if they're all true.
The Many Uses of Coca-Cola
1. To clean a toilet: Pour a can of Coca-Cola into the toilet bowl. let the "real thing" sit for one hour, then flush clean. The citric acid in Coke removes stains from vitreous china.
2. To remove rust spots from chrome car bumpers: Rub the bumper with a crumpled-up piece of Reynolds wrap aluminum foil dipped in Coca-Cola.
3. To clean corrosion from car battery terminals: Pour a can of Coca-Cola over the terminal to bubble away the corrosion.
4. To loosen a rusty bolt: Applying a cloth soaked in Coca-Cola to rusted bolt: Applying a cloth soaked in Coca-Cola to the rusted bolt for several minutes.
5. To bake a moist ham: Empty a can of Coca-Cola into the baking pan; wrap the ham in aluminum foil, and bake. Thirty minutes before the ham is finished, remove the foil, allowing the drippings to mix with the Coke for a sumptuous brown gravy.
6. To remove grease from clothes: Empty a can of Coke into a load greasy clothes, add detergent, and run through a regular cycle.
7. The Coca-Cola will help loosen grease stains. It will also clean road haze from your windshield.
AND WE DRINK THIS STUFF:
FYI- The active ingredient in Coke is phosphoric acid. It's pa is 2.8. It will dissolve a nail in about 4 days.
The distributors of coke have been using it to clean the engines of their trucks for about 20 years.
Drink up.
