RE: TF P47 .60 Balancing Act
9.2 lbs, with the Saito 100. I just don't have the fuel lines installed in the tank. 2700 mah battery. I haven't balanced it either, so the weight could possible go up if I need to add some to make it balance. I am very happy with this figure.
Bigtim, I hope you guys find another field. Mine is just covered with snow and slush right now. Not quite enough snow or water for pontoons or ski's.
I forgot to add, when installing the replica radial, you only want that about 1/2" from the front lip of the cowl, mine is back further, I wouldn't have epoxied it in first if I thought I would have to do that much trimming on the baffle plate to fit it.
