RE: hobbyzone vs eflite?
If you've some experience with the J3 I'd look at the Multiplex MiniMag, it's as durable if not more so than the Super Cub, can be set up as 3 channel to start with but you install the servo's for ailerons when you build it and then just plug them in when you're ready and you've a 4 channel aileron plane.
Get a Simulator as well as it'll make a huge difference with orientation.
