http://www.chatfield-clarke.com/viny...ds/default.htm
I use vinyl tack board screwed to a solid core door and set that on my work table. Got the door from Home Depot (damaged door discounted). I get the tack board from work. It's a school district, and they have cut pieces that they throw away. The tack board sheets come 4' x 8' and a lot of times they cut off sections for smaller areas and end up with various left over size pieces. The tack board works great, and holds pins in place. Someday though, I'm going to switch to the magnetic system.
