ORIGINAL: FalconWings10
Has anyone had a problem with the horizontal stabs not fitting against the aft side of the fuse? Mine has about a 1/16" gap on both sides.
You may rotate and re-drill/tap the stab tube as necessary to get the fit you like. Also, over time, vibration makes the fiberglass tubes in the the wings and stab lose material and get sloppy. I "sweat" mine with thin CA on a swab to build them back up now and then.
ScottK
