RCU Forums - View Single Post - My homey in yak....
Old 12-01-2008 | 09:03 PM
captinjohn
Default RE: My homey in yak....
You may want to replace metal cable to carb and use plastic ny-rod. The set-up you have may have radio glitches. Is the power switch to the ignition held in place? Make sure you do a good radio check with engine running before flying airplane. Have someone help you. Good Luck capt,n
