RE: My homey in yak....
Yes,the ignition switch is mounted to the right side of the fuse. You can see it in the 2nd pic at the bottom. And yeah,I kinda hated to hook up the throttle up with that cable,but I did have the US 41 hooked up with a 4-40 rod which was alittle closed to the reciever with no problems. I will however check the hobby shop tomarrow for some flexible stuff. Not sure if I can get some nyrod flexible enough though.
