RCU Forums - View Single Post - Please help with this Byron fan question.
Old 03-19-2002 | 10:41 PM
drywaller
Default Please help with this Byron fan question.
I have a Byron fan and have a common problem with it.
Here goes. When asembled, the rotor hits the shroud. The instructions say this is "normal" and to just run the engine "in" and the contact will "wear in" by itself.
I called TopGun Aircraft and was told by them to just trim the mounting lugs on the engine mount untill I get the proper clearance. If I do it that way then the fan will not sit square in the shroud.
Has anyone come up with an alternative cure for this?
Please help me with this one.
Thank you, Marco.
